About Cisco Wireless acces point
Nizam.Ahmed
Level 4
Level 4
Hi Experts,
I could not access the APs even SSh/telent and web. The APs are managed by WLC. I can ping all of the APs but could not access all APs GUI mode also.
Please suggest me.
 You can access gui on a access point when in wlc. You do have access through telnet/ssh if you allow it first.
 On the AP general tab, you can define the username and password and on the AP advanced tab you can check overwrite global credentials. Works for me.
-If I helped you somehow, please, rate it as useful.-
patoberli
Also there is usually no need to connect to the AP, if it's managed through the WLC, because all configuration is done on the WLC, nothing on the AP.
The APs don't have a GUI when in lightweight mode, only SSH/Telnet, which is disabled by default.
