About Meraki APs Licensing
Yohan1
Level 2
Level 2
Do we need additional licensing if we use Meraki APs as a gateway for Meraki Sensors?
RWelch-USA
Meraki Community All-Star
No, as long as the AP and MT both have their own license they will work together. The only other aspect you might want to keep in mind is to not exceed the max per gateway.
How many sensors can be used per gateway?
It is recommended to have a maximum of 32 sensors per gateway to ensure connection quality.
6 Replies 6
RWelch-USA
Imagine I already have AP license, so you means we just need the license for sensor right?
RWelch-USA
I would check your dashboard inventory to see if you happen to have any MT licenses. If so, you can use them. If not, you'd need a MT license for each MT device.
MT Frequently Asked Questions
Ok.
Thank you for your support @RWelch2
Philip D'Ath
Also note that every org gets 5 free sensor licences.
https://documentation.meraki.com/MT/MT_General_Articles/MT_Frequently_Asked_Questions#2_Free_MT_Licenses_with_MR_Advance_License
Also note if you use MR Advanced licencing you get two "free" sensor licences for every MR Advanced licence that you have (in the same link as above).
