Acceptable signal strength?
Hi everyone--i find myself having to venture out into the realm of wireless (I'm more of a UC/DC engineer...) and i've got a problem i'm trying to track down.  Installed two WLC 5508s, WCS, 3502i APs (123 of them...) in a 4-floor high school.  What i'm finding is lousy throughput from a lab of PCs with little USB b/g/n adapters.  I took my Macbook in and ran iStumbler to get an idea of the SNR but honestly, i'm not sure what i'm looking for.
For the particular room/SSID/band that i was looking at, i found that in the 2.4 range, i was getting 53% signal strength and about 16% noise.  Is that a good level?  In WCS, i can see close to a dozen APs in relation to the AP in question, so i'm wondering if the SNR is too high...not sure what to tune/tweak/do to make it perform better...
Any ideas would gladly be welcome.
Thanks all
SJ
15 Replies 15
Leo Laohoo
How many WAPs and how many of these PC's?
What kind of traffic are you dealing with?  Browsing the web?  Video download?
1 ap in the room. 16 pcs. Just logging into the machines takes between 7-10 minutes per box. In other areas, it's much speedier by comparison.
Scott A. Jones, CCVP
IPLogic, Inc.
Sent from my iPhone
Hmmmm ... Somethings not right.
This particular WAP is connected on a FULL duplex link with the switch, right?
If you console into the WAP and do a "sh log", what output do you see?
I see the IDS engine detecting a replay attack about once a day, then it clears and the dot11radio0 resets. It’s full-duplex, 1Gb speed. One thing interesting yesterday—it reported the replay attack, but I was the only one in the building, trying to login to one of the PCs in question (the rest were logged off).
Check to see if the users are connecting to that ap or an ap nearby.  Is this the only dense area that you have issues with?
-Scott
Great point—I did notice they all connect to that AP. There is one other area that had issues…a lab with about 2 dozen iMacs. Moved them to WPA2 security so that N would work, and they picked up a little bit. Eventually they hard-wired the lab, so that one went away. Tried that with the lab in question, issue still persists…
One thing I noticed though—on the show interface, there’s a really high number of unknown protocol drops on the gi 0 interface of the AP. Not sure if that could be related…
Can you post the show wlan
-Scott
Just had a chance to jump in to the AP.  It doesn't recognize that command...i guess i should specify they're LWWAPs, so should i be running that command on the controller?
That command needs to be ran from the wlc CLI. The WLAN id is the SSID that is having the issues.
-Scott
Sorry about that! The joy of learning as you go…output is below
WLAN Identifier.................................. 2
Profile Name..................................... old HS wireless
Network Name (SSID).............................. HS-Wireless
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 290
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ old-hs-wireless
Multicast Interface.............................. Not Configured
More or (q)uit
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ Global Servers
More or (q)uit
Accounting.................................... Global Servers
Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
802.11 Authentication:........................ Open System
Static WEP Keys............................... Enabled
Key Index:...................................... 1
Encryption:..................................... 104-bit WEP
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web-Passthrough............................... Disabled
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
H-REAP Local Switching........................ Disabled
H-REAP Local Authentication................... Disabled
H-REAP Learn IP Address....................... Enabled
Client MFP.................................... Optional but inactive (WPA2 not configured)
Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
More or (q)uit
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Enabled
Load Balancing................................... Disabled
Scott Fella
That looks okay. So the issue is only with iMacs, nothing else. These the newer iMacs or older ones? You mentioned you tried using WPA2 so why did you go back using WEP. If the iMac support WPA2/AES, then I would use that. Along with WMM being required for 802.11N. All you really need to do is set the 802.11an channel to 40mhz.
-Scott
That’s a great tip for the a/n spectrum. I’ll do that. In the lab I’m having issues with though, it’s a bunch of PCs running b/g/n only adapters. The iMacs were a separate thing and have since been hard-wired, so they’re not so much of a problem anymore. Any thoughts on things I can tweak for the 2.4 GHz?
As far as the switch between WPA2 and WEP, the WEP is there to support machines that were moved in (they’ve only been in this building for around 3 weeks…). They won’t be able to switch things around until summer. I did try moving a couple of the PCs to the WPA2 test network, but with the same results…I wish I could test a/n but the cheap adapters prevent that.
Appreciate the help
SJ
That is okay.... You can still achieve up to 144mbps on the 2.4ghz. All you need is WPA2/AES and WMM enabled. The thing with WEP is that sometimes you can't use key #1. Maybe moving the WEP key to key #2 might help but you would need to change that on the devices also. If you have to make changes, its probably better to jut move those machines to WPA2.
Scott Fella
Sent from my iPhone
-Scott
Ok. I’ll give it a shot and let you all know what happens. Thanks for the info.
SJ
