Access Point connecting to switch
hey,
I have a small issues with my tp-link AP, I try to connect the ap with a switch 2950 and I can't access the net.
To be clear
->I set on a port the access mode, vlan, switchport security, etc
interface FastEthernet0/10
switchport access vlan 55
switchport mode access
switchport nonegotiate
switchport port-security maximum 6
switchport port-security mac-address sticky
speed 100
duplex full
spanning-tree portfast
spanning-tree bpduguard enable
ip dhcp snooping limit rate 6
what can i do?
patoberli
You are running port-security. Every client attached to the AP might appear as another mac-address and completely filling up the allowed 6 addresses, unless the AP is in router-mode. You might want to disable this.
Mark Elsen
                        - What do you mean by I can't access the net ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Scott Fella
I don't also fully understand your question, but since you have a switch, what if you connect a laptop to a port that is also on vlan 55?  You get network connectivity and also access the internet?
-Scott
patoberli
Thank you all the help, I disable the port security and now is working, thanks guys
