Bookmark
Subscribe
14051
Access Point Disjoined/Joined to vitual WLC 9800
Hi everyone!
If someone can help me. I was trying to associate AP (9130 AXI) to virtual WLC 9800CL. It was successfull but after some minutes I can see the AP was disjoined, then it was joined again, Let me show you some logs on WLC:
Nov 15 18:41:49.038: %CAPWAPAC_SMGR_TRACE_MESSAGE-3-WLC_GEN_ERR: Chassis 1 R0/0: wncd: Error in Session-IP: 172.16.40.2[5248] Mac: b811.4bef.a700 Maximum retries for sending CAPWAP message reached. Close CAPWAP DTLS session
Nov 15 18:41:49.039: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: AP687D.B494.4464, MAC: 687d.b494.4464 Disjoined
Nov 15 18:45:53.767: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: AP687D.B494.4464, MAC: 687d.b494.4464 Joined
Nov 15 18:46:34.114: %APMGR_TRACE_MESSAGE-6-WLC_APMGR_INFO: Chassis 1 R0/0: wncd: Info : - Enable dual radio mode failed, AP mac: b811.4bef.a700 slot: 1, reason: global triradio status is disabled
Nov 15 18:54:32.970: %WEBSERVER-5-SESS_LOGOUT: Chassis 1 R0/0: : Successfully logged out from host 172.16.40.20 by user 'admin' using crypto cipher 'ECDHE-RSA-AES128-GCM-SHA256'
Nov 15 18:56:44.140: %APMGR_TRACE_MESSAGE-6-WLC_APMGR_INFO: Chassis 1 R0/0: wncd: Info : - Enable dual radio mode failed, AP mac: b811.4bef.a700 slot: 1, reason: global triradio status is disabled
Nov 15 18:58:49.207: %WEBSERVER-5-LOGIN_FAILED: Chassis 1 R0/0: : Login Un-Successful from host 172.16.40.20
Nov 15 18:58:57.501: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: admin] [Source: 192.168.1.5] [localport: 21111] at 18:58:57 UTC Mon Nov 15 2021
Nov 15 18:58:57.502: %WEBSERVER-5-LOGIN_PASSED: Chassis 1 R0/0: : Login Successful from host 172.16.40.20 by user 'admin' using crypto cipher 'ECDHE-RSA-AES128-GCM-SHA256'
Nov 15 18:59:09.622: %SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart License Utility (CSLU) : Unable to resolve server hostname/domain name
Nov 15 19:06:54.165: %APMGR_TRACE_MESSAGE-6-WLC_APMGR_INFO: Chassis 1 R0/0: wncd: Info : - Enable dual radio mode failed, AP mac: b811.4bef.a700 slot: 1, reason: global triradio status is disabled
Nov 15 19:09:18.967: %SYS-5-CONFIG_P: Configured programmatically by process SEP_webui_wsma_http from console as admin on vty0
Nov 15 19:13:14.527: %CAPWAPAC_SMGR_TRACE_MESSAGE-3-WLC_GEN_ERR: Chassis 1 R0/0: wncd: Error in Session-IP: 172.16.40.2[5248] Mac: b811.4bef.a700 Heartbeat timer expiry for AP. Close CAPWAP DTLS session
Nov 15 19:13:14.534: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: AP687D.B494.4464, MAC: 687d.b494.4464 Disjoined
Nov 15 19:14:41.423: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: AP687D.B494.4464, MAC: 687d.b494.4464 Joined
Nov 15 19:17:04.189: %APMGR_TRACE_MESSAGE-6-WLC_APMGR_INFO: Chassis 1 R0/0: wncd: Info : - Enable dual radio mode failed, AP mac: b811.4bef.a700 slot: 1, reason: global triradio status is disabled
Nov 15 19:18:19.631: %CAPWAPAC_SMGR_TRACE_MESSAGE-3-WLC_GEN_ERR: Chassis 1 R0/0: wncd: Error in Session-IP: 172.16.40.2[5248] Mac: b811.4bef.a700 Heartbeat timer expiry for AP. Close CAPWAP DTLS session
Nov 18 15:31:19.669: %SYS-5-CONFIG_P: Configured programmatically by process SEP_webui_wsma_http from console as admin on vty0
Nov 18 15:32:03.163: %SYS-5-CONFIG_P: Configured programmatically by process SEP_webui_wsma_http from console as admin on vty0
Nov 18 15:32:45.644: %CAPWAPAC_SMGR_TRACE_MESSAGE-3-WLC_GEN_ERR: Chassis 1 R0/0: wncd: Error in Session-IP: 172.16.40.2[5248] Mac: b811.4bef.a700 Heartbeat timer expiry for AP. Close CAPWAP DTLS session
Nov 18 15:32:45.648: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: AP687D.B494.4464, MAC: 687d.b494.4464 Disjoined
Nov 18 15:34:53.362: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: AP687D.B494.4464, MAC: 687d.b494.4464 Joined
Nov 18 15:37:44.005: %APMGR_TRACE_MESSAGE-6-WLC_APMGR_INFO: Chassis 1 R0/0: wncd: Info : - Enable dual radio mode failed, AP mac: b811.4bef.a700 slot: 1, reason: global triradio status is disabled
Nov 18 15:44:21.077: %SYS-5-CONFIG_P: Configured programmatically by process SEP_webui_wsma_http from console as admin on vty0
Nov 18 15:47:54.041: %APMGR_TRACE_MESSAGE-6-WLC_APMGR_INFO: Chassis 1 R0/0: wncd: Info : - Enable dual radio mode failed, AP mac: b811.4bef.a700 slot: 1, reason: global triradio status is disabled
Nov 18 15:48:01.196: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: admin] [Source: 172.16.40.101] [localport: 22] at 15:48:01 UTC Thu Nov 18 2021
Nov 18 15:55:42.552: %APMGR_TRACE_MESSAGE-4-WLC_APMGR_WARNING_MSG: Chassis 1 R0/0: wncd: Warning, AP AP6C71.0DF2.1BC0 is associated with the policy tag default-policy-tag, which has no wlan or rlan configured. Please configure wlan or rlan under the policy tag or associate the AP with valid policy tag
Nov 18 15:55:42.556: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: AP6C71.0DF2.1BC0, MAC: 6c71.0df2.1bc0 Joined
Nov 18 15:58:04.070: %APMGR_TRACE_MESSAGE-6-WLC_APMGR_INFO: Chassis 1 R0/0: wncd: Info : - Enable dual radio mode failed, AP mac: 3c41.0efe.75e0 slot: 1, reason: global triradio status is disabled
Nov 18 15:58:14.812: %SYS-6-TTY_EXPIRE_TIMER: (exec timer expired, tty 1 (172.16.40.101)), user admin
Nov 18 15:58:14.813: %SYS-6-LOGOUT: User admin has exited tty session 1(172.16.40.101)
Nov 18 16:04:33.310: %CAPWAPAC_SMGR_TRACE_MESSAGE-3-WLC_GEN_ERR: Chassis 1 R0/0: wncd: Error in Session-IP: 172.16.40.2[5248] Mac: b811.4bef.a700 Heartbeat timer expiry for AP. Close CAPWAP DTLS session
Nov 18 16:04:33.313: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: AP687D.B494.4464, MAC: 687d.b494.4464 Disjoined
Nov 18 16:04:50.323: %CAPWAPAC_SMGR_TRACE_MESSAGE-3-WLC_GEN_ERR: Chassis 1 R0/0: wncd: Error in Session-IP: 172.16.40.3[5272] Mac: 3c41.0efe.75e0 Heartbeat timer expiry for AP. Close CAPWAP DTLS session
Nov 18 16:04:50.324: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: AP6C71.0DF2.1BC0, MAC: 6c71.0df2.1bc0 Disjoined
Nov 18 16:08:51.182: %APMGR_TRACE_MESSAGE-4-WLC_APMGR_WARNING_MSG: Chassis 1 R0/0: wncd: Warning, AP APCC7F.75AE.0FD0 is associated with the policy tag default-policy-tag, which has no wlan or rlan configured. Please configure wlan or rlan under the policy tag or associate the AP with valid policy tag
Nov 18 16:08:51.207: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: APCC7F.75AE.0FD0, MAC: cc7f.75ae.0fd0 Joined
Nov 18 16:12:26.479: %CAPWAPAC_SMGR_TRACE_MESSAGE-3-WLC_GEN_ERR: Chassis 1 R0/0: wncd: Error in Session-IP: 172.16.40.4[5264] Mac: a488.7373.fd20 Heartbeat timer expiry for AP. Close CAPWAP DTLS session
Nov 18 16:12:26.483: %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: APCC7F.75AE.0FD0, MAC: cc7f.75ae.0fd0 Disjoined
Today I had the same problem with another AP, the wlc version is 17.3.3 (recomended).
If Someone know how to solve it, I would really appreciate it.
is the time and timezone in WLC is correctly configured?
Good luck
KB
Good luck
KB
balaji.bandi
1. First i would check Physical connection, what logs you see where the AP connected ?
2. Maybe  BUG
3. is this only AP having issues with all other AP, and is this first-time setup, working one broken?
Also please post the information below :
- WLC:  sh sysinfo
- WLC:  sh time
- AP:  sh version
- AP:  sh ip interface brief
- AP:  sh inventory
BB
Arshad Safrulla
Since you are running a Catalyst WLC, please post a Radio Active trace for the AP MAC address.
I would also like you to check and make sure that you have followed the deployment guide published by Cisco.
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-cl-wireless-controller-cloud/nb-06-cat9800-cl-wirel-cloud-dep-guide-cte-en.html
Pay attention to all the steps listed under “Configuring the 9800-CL via the CLI: Skipping the DAY 0 guided flow”
As Kasun mentioned  above make sure that the NTP is synced.
