Access Point Initial Distribution
Robert Wilbur
Community Member
When deploying the 2702 and 571 APs, what is the suggested distance between them for maximum coverage?
Rasika Nayanajith
Keep in mind increasing coverage does not help unless your clients can communicate  back with that AP. So AP power level should be match to client capability (~ 11dBm)
consider this when placing APs.
Rasika
*** Pls rate all useful responses ***
sobhardw
It is recommended that you space each AP apart by approximately 6 Ft (2 meters). Avoid clustering the APs or the antennas from different APs together because this could cause degradation in performance. This recommended distance is based on the assumption that both devices operate in the unlicensed band and do not transmit RF energy more than 23 dB–that is, 200 mW. If higher power is used, space the APs farther apart.
For More Information on deployment of Access Point , Please follow the below Link
http://www.cisco.com/c/en/us/td/docs/wireless/technology/apdeploy/8-0/Cisco_Aironet_3700AP.html/index.html#pgfId-73791
