Access point SSID not showing
Aziz.zahrani
Dear All
I have more than 50 AP (cisco aironet 1142) ,switch and WLC.
befor 3 days  power outage occurred  after resetart some of the AP can not showing the name of WiFi .
i take internet from the switch to my laptop by cable it is work.
but when i try to connect to WiFi it is not showing on the laptop or iphone or any device
the AP is working  and light is green.
thank you
8 Replies 8
marce1000
  - Check the status of the radio's on those AP's through the controller GUI.
 M.
can you explain it more for me becuse i don't have experince on it .
thank you
 - Check this guide :
           https://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_01101001.html
 M.
balaji.bandi
Do you mean SSID, not broadcasting, and user device not able to see SSID?
check the AP group has that SSID?
check WLAN config and SSID config might have lost or not saved before power outage ?
BB
Yes i mean that .
and i check AP groups i don’t find any AP there .
How can i add AP to group from GUI ?
thank you
Choose WLANs > Advanced > AP Groups to open the AP Groups page.
You see add and remove left side added, right side AP available to Add ( AP reboot once you add to AP Group)
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/configuring_ap_groups.html
BB
if you have a videos palease put the link
thank you
Have you come across any time Youtube.com ?
"How to add AP  to AP Group using Cisco WLC  GUI"   - type in google. com - then  click Videos, you find plenty...
BB
