Access point with built-in position sensor
stephan wyss
Frequent Visitor
Frequent Visitor
Hello, I would like to ask whether any considerations have been made to install location sensors in access points?
This would make it possible to check in which position the APs have been installed, whether the installer has installed them the right way round and enable alarms if the AP is tampered with.
y73 hb9fiz
Telematiker HF
0 Replies 0
