Access Points Low Power Issue
VineeshVijayan
Frequent Visitor
Frequent Visitor
Hi Experts,
I'm getting multiple alerts from Prime regarding the issues in Access points. below is the log message.
''Message: Access point 'XXXXXX' associated with controller 'XXXXX' draws low power from Ethernet. Failure reason: 'The AP draws 15.4 watts from Ethernet'. (6 times)''
The access points are working before without any issue, this issue is started recently.
Please provide any solution to this.
Thanks in Advance!
Spoiler
Spoiler
9 Replies 9
Mark Elsen
          - Could be a controller-bug, for that check if the message is duplicated in the controller-logs (too).
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
Is this error message coming out of Cisco Prime Infrastructure?
Yes, this is the email alert from Cisco Prime.
I recommend ignoring this alarm.
Could you please explain why?
Bug with PI.
Arshad Safrulla
What is the AP model and what POE standards does the switch support?
Hi Arshadsaf,
Please note the power inline command output below.
Interface Admin  Oper       Power   Device              Class Max
Gi0/4     auto   on         16.8    AIR-CAP3702E-E-K9   4     30.0
since your switch is POE+ capable, pls check your switch POE budget and it's consumption. If they are within limits then you may ignore this error messages.
Only time I have seen this messages were when a 3700 connected to a 3560 switch which was only delivering af.
