Access Points not registering with WLC
deepakdubbas
Access points are not able to join to WLC from a specific location, but where as same model of AP's are registered and are working,
WLC model -- AIR-CT5508-K9
AP Model--AIR-AP1252AG-A-K9
WLC IOS version -- 8.0.135.0
 we have 5 to 8 No's on same model AP's none of them are working, we tried resetting, erasing the files from flash, configuring Manually. but Registeration is not happening. similar models are available at other locations which are registed with this same WLC, but we are experiencing the issue with only specific location
But Ap's are pinging from WLC and from APconsole we can ping WLC IP address.
Please suggest a way forward
Thank you.
ThanK you Leo, Let me try the suggested work around steps, will keep posted as we implement the changes.
Thanks again for this info.
Note that for a permanent resolution to the issue you need to follow all the steps in the field notice including configuring:
config ap cert-expiry-ignore {mic|ssc} enable
