AD Auth SSID on C9800
ToddLewis13460
I am looking to configure an AD authenticated SSID on a C9800 WLC.  In the past I have been able to successfully do this from the 5500 series controllers to a Windows NPS server.  However when I try and configure the C9800 with a Windows NPS server I get an error on the server that says that it cannot process this type of EAP request.  Can I set this up this way or does the C9800 only authenticate to the ISE product?
marce1000
  - What's the software version on the 9800 and or use the most recent release to verify this issue.
 M.
software version is 16.12.03.
9800 should support any RADIUS server, not limited to ISE. You require to configure the same shared secret on 9800 and NPS.
Hope you follow the configuration guideline for 9800 given below
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213919-configure-802-1x-authentication-on-catal.html
As long as you configure NPS for basic client auth/authorization policy it should work. Below post may give some idea how you should configure NPS
http://wifinigel.blogspot.com/2014/03/the-microsoft-network-policy-server-nps.html
Rasika
Try with 17.4.1 like marce100 suggested.  Features and fixes having been coming thick and fast in the 9800 code.
