Cisco Access Point Client Connection Always Drop
am.
We have a problem here, this has been happening since 1 year ago. Client connections from the access point in our office are always drop randomly.
We are using Cisco Catalyst 9800-L-F (IOS-XE 16.12.4a) and Cisco Aironet 1815i.
The average device in our office uses Windows 10 with an Intel chipset.
When the problem occurs, the wifi indicator on the computer is still connected but has no internet connection, and cannot ping to the gateway.
However, the device can connect to the access point and get an IP address, even the client is still detected in WLC.
We have tried to open the case to Cisco TAC, we have done OTA Capture and Span Capture but until today we still have not found an answer.
I hope you can share your experiences on this issue. I hope to get a solution from you.
patoberli
What did you do so far with TAC?
How well can you reproduce the problem?
>debug client <mac address>
> whether the user is authentication is dropped ?
Leo Laohoo
What timezone/country are you in?
  1. Does this issue ONLY appears on the corporate laptop?
  2. Does this issue appear on, say, Apple or Android OS?
  3. Can you try rebooting the AP first?  If issue still does not go away, reboot the WLC next.
Have you checked that you're using the latest drivers on the PCs?  That can solve lots of problems.
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
