Add AP 1602 to controller Ap1852
info-85
I have some old AP air-sap1602-e-k9 in version 153.3-JD who are self managed.
In same time i have some AP AIR-AP1852E-E-K9 (in version 8.10.151.0) and one of them is the controler Cisco Aironet 1850 Serie Mobility Express.
Does it's possible to add my air-sap1602-e-k9 on the controler for simplify the management and have exactly the same config on all my APs ?
I try to update my air-sap1602-e-k9 to the latest firmware : After the update i can't access to the web interface of the AP and the AP doesn't see in the controler !
I screenshot the console of the air-sap1602-e-k9 , i can see it try to join the controler without success.
Do you have any idea ?
Thank's
5 Replies 5
sorry. 1602 is not compatible to mobility express 8.10.151.0
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#mobility_express_solution
1600 last supported mobility express OS is 8.5.17x.0
Good luck
KB
Thank's for the information !
So i can't update my AP 1602 to the latest firmware ?
In version 153-3.JD : it's work fine in self management but when i update it to
15.3.3-JF15ED
i can't mange it anymore.
Do you know why ?
Than'ks
My bad !!
I downloaded the Lightweight version of the firmware not the Autonomous version !
unfortunately i'm not allowed to download the Autonomous versions of firmwares
Thank's for your answer
balaji.bandi
Personally, i do not see AP as a compatible list :
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/release_notes/b_ME_RN_810.html
BB
Rich R
And beware of using latest autonomous code because many people have reported problems with the GUI in the latest code.  So your best option may be to remain on the same old autonomous code.
