Add multiple mac addresses to wlc using cli
Johney1
Community Member
I have a spreadsheet of Mac addresses and description that I need to add to WLC all at once using CLI. can someone help with command. i know that for a single mac, i will use macfilter add under config mode. how do I add all at once.
Thank you
J
d.friday
Level 8
Level 8
have column 1 with the following cli config macfilter add
 column 2  would have the mac address delimited by :
then column 3  use formula =(A1&" "&B1)
look at the attachment
you would copy just column 3 row  by row into your WLC
