AP1572EAC DO NOT POWER ON
Rafael Jimenez
Level 4
Level 4
I have one air-ap1572EAC-A-k9 with its power injector AIR-PWRINJ1500-2=.
I just plugging the cable to the AP from the injector but the AP do not turn on
whats is the problem?
Rafael Jimenez
Level 4
Level 4
I did a test with the AIR-CORD-R3P-40NA=. Tha 1572EAC works fine.
somebody knows if there is a kind of trick with this ap using the 1500-2 injector?
I purchased two and tested both with the same result.
