Adding 3rd SSID to Cisco 3702i AP in autonomous mode
Andrew White
Level 2
Level 2
I've got a Cisco 3702i running 2 SSIDs.  1 on 2.4Ghz and the other on 5Ghz, I wanted to add another 2.4Ghz SSID but I can't.
What I have:
dot11 pause-time 100
dot11 syslog
dot11 ssid Area51-2.4Ghz
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 ****
dot11 ssid Area51-5Ghz
   authentication open
   guest-mode
   wpa-psk ascii 7 ***
no ipv6 cef
bridge irb
interface Dot11Radio0
 no ip address
 encryption mode ciphers aes-ccm
 ssid Area51-2.4Ghz
 antenna gain 0
 stbc
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 ssid Area51-5Ghz
 antenna gain 0
 peakdetect
 no dfs band block
 stbc
 channel width 80
 channel dfs
 station-role root
 bridge-group 1
If I go to the interface 'Dot11Radio 0" where my current 2.4Ghz SSID is I can't add another:
Dot11Radio0: Guest-ssid already existing on ssid MyNet-2.4Ghz
Do I have to create a new sub interface like 0.1 and somehow bind it to the BVI?
I have no idea.
Sandeep Choudhary
Just enable mbssid under the radio interface and then you can add the command "mbssid guest-mode" under each SSID config. This will allow multiple SSID's to be broadcast from the AP.
Dont forget to rate hlepful posts
balaji.bandi
yes, correct you need another subinterface to accommodate.
here is sample document :
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/service-set-identifier-ssid/116118-configure-ap-ssid-ios.html
BB
