Adding another mgt interface 2504
Eric Kemsley
Level 4
Level 4
How do I add another management interface to a 2504 controller? I have port 1 setup when I first installed the WLC. But I want port 2, with a different ip address, to be able to access the WLC too.
port 1 = 10.0.0.1/24 which works ok.
port 2 - 10.17.1.25/16 is the other port i want.
Scott Fella
If you created a dynamic interface and assigned that to port 2, what you need to do to access the WLC management is to allow management via wireless using the dynamic interface.  This is the command you need to enter:
config network mgmt-via-dynamic-interface enable
-Scott
-Scott
Scott Fella
-Scott
-Scott
