Adding (dynamic) interfaces to WLC 2504 causes loss of network
3moloz123
I'm trying to add a new dynamic interface, that I will tie a specific WLAN to so that clients on that WLAN is in the correct vlan. After adding it I loose connectivity both to the main management address (10.99.0.60) and to the ip address of the dynamic interface (10.99.12.4). In fact, the dynamic interface address responds and prompts me to login, but after doing so all I get is a blank page. Here's the two interfaces pulled from the CLI - what am I doing wrong?
And oh, not adding an IP to the dynamic interface makes it impossible to use within a WLAN.
Interface Name................................... management
MAC Address...................................... c0:8c:60:c7:99:00
IP Address....................................... 10.99.0.60
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.99.0.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 31
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 10.99.0.1
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
IPv4 ACL......................................... Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Enabled
Interface Name................................... lan
MAC Address...................................... c0:8c:60:c7:99:04
IP Address....................................... 10.99.12.4
IP Netmask....................................... 255.255.252.0
IP Gateway....................................... 10.99.12.1
VLAN............................................. 33
NAS-Identifier................................... mob-wlc
Primary DHCP Server.............................. Unconfigured
AP Manager....................................... No
17 Replies 17
Update, I managed to get it working after all. Make sure LAG is enabled and it has basic connectivity and LAG is up with allowed VLAN's that you wan to permit for your WLC. You should also always use 2 gig port setup when using LAG. Having LAG with only 1 port is somewhat pointless after all.
Also if not using Cisco switches dont allow native VLAN 1 over the LAG since CDP can cause issues.
If this WLC is on DMZ make sure you have proxy ARP enabled.
cheers!
Saravanan Lakshmanan
wlc code?
for test,
try using /16 for management and keep the remaining config.
or use multiple /24 for dyn.int along with interface group.
or use different mask than /252 for dyn.int.
jhoude660
Was there ever a resolution to this. I seen the same issue on two seperate controllers.
