DC connector and Power Supplied for AIR-AP1572EC1-A-K9
I have a brand new Access point for our Mesh Network, the model is: AIR-AP1572EC1-A-K9, this is not working either with Poe or power Injector, I'd like to know what is the power supplied that I need for the connector PN:29-100226-01, I'll be waiting for your comments.
soportefibratel
Model
AP1572IC
AP1572EC
AP1572EAC
Antennas
Internal antennas
External antennas
Input power options
  • Power-over-Cable, via Cable Modem
  • DC
  • DC
  • AC Power
  • DC
  • PoE-In
    (Standard UPoE or AIR-PWRINJ1500-2 power injector)
AC Power Supply
Non PoC versions of the AP come equipped with an AC power supply. The power supply is designed to accept AC voltage from 100 V to 277 V RMS.
The following AC power cords are supported:
Product ID
Description
AIR-CORD-R3P-40NA=
Power cord, 40 ft, North American Plug
AIR-CORD-R3P-40UE=
Power cord, 40 ft, European Harmonized, Unterminated
AIR-PWR-ST-LT-R3P=
Power cord, 4 ft, Street Light Tap
For connecting Streetlight AC power to the access point, see Connecting Streetlight AC Power.
For connecting an AC power supply to the access point, see Connecting an AC Power Cable to the Access Point.
DC Interface
All versions of the AP have an externally accessible DC input connector. The DC input accepts voltages in the 10 to 16V range. The power supplied should be 10 amp.
For connecting a DC power supply to the access point, see Connecting a DC Power Cable to the Access Point.
PoE-Input
AC powered versions of AP1572EAC can be powered by UPOE compliant power sourcing equipment.
In addition to being powered by UPOE sources, the access point can also be powered by the AIR-PWRINJ1500-2 power injector.
The access point also supports an Ethernet uplink port (PoE-In). The access point Ethernet uplink port uses an RJ-45 connector (with weatherproofing) to link the access point to the 10BASE-T, 100BASE-T or 1000BASE-T network. The Ethernet cable is used to send and receive Ethernet data and to optionally supply inline power from the power injector or a suitably powered switch port.
Tip The access point senses the Ethernet and power signals and automatically switches internal circuitry to match the cable connections.
The Ethernet cable must be a shielded outdoor rated Category 5e (CAT5e) or better cable. The access point senses the Ethernet and power signals and automatically switches internal circuitry to match the cable connections.
Depending on the version of the AP, a 1572 series access point supports these power sources:
  • Power-over-Cable on AP1572IC and AP1572EC versions
  • AC power on AP1572EAC version
The 1572EAC access point can be powered via the PoE input from an in-line power injector or a suitably powered switch port. The AIR-PWRINJ1500-2= power injector can be used.
soportefibratel
Model
AP1572IC
AP1572EC
AP1572EAC
Antennas
Internal antennas
External antennas
Input power options
  • DC
  • DC
  • AC Power
  • DC
  • PoE-In
AC Power Supply
Product ID
Description
AIR-CORD-R3P-40NA=
AIR-CORD-R3P-40UE=
AIR-PWR-ST-LT-R3P=
DC Interface
PoE-Input
Model
AP1572IC
AP1572EC
AP1572EAC
Antennas
Internal antennas
External antennas
Input power options
  • DC
  • DC
  • AC Power
  • DC
  • PoE-In
