Advantage of Disabling Low Data Rates
jpl861
Level 4
Level 4
Hi there guys,
Is there any advantage if I disable all the low data rates of both 802.11a and 802.11b/g? I have read that in order to totally disable 802.11b clients, data rates 1, 2, 5.5, and 11 must be disabled. But I am also thinking of setting the minimum mandatory to 12Mbps and disable the 6 and 9Mbps data rates as well.
Is there going to be an advantage and would it break anything?
John
Philip D'Ath
Lets say a client has to download 10MB.  Downloading that at 1Mb/s will take a lot longer than at 300Mb/s.  Consequently, that 1Mb/s user will need a lot more airtime - airtime that can then not be used by other users.  So that 1Mb/s user has now slowed down every other user of the WiFi network.
So yes, as long as you have plenty of coverage I would disable all the older "legacy" data rates.
There are similar discussions about the Data rates disable. Please look into the below links which can give you more guidance.
https://supportforums.cisco.com/discussion/11262131/data-rates-best-practices
https://supportforums.cisco.com/discussion/11121546/data-rates-mandatorysupporteddisabled
Hope this will help you.
