ā11-21-2024 02:35 AM
I'm planning a new wireless deployment and want to use these 2 antennas:
AIR-ANT2588P4M-NS
AIR-ANT2513P4M-NS
Both have a higher gain then 6 dBi and from what I understooth and Cisco documentation I need to use the 9120AXP AP.
Now i'm confused on what kinda connectors the 9120AXP have. I cannot find a clear picture and information about the connectors.
Do i need to use the DART connector or does the 9120AXP have the same connectors as 9120AXE?
Is anybody familiar with these APs and antennas?
Solved! Go to Solution.
ā11-21-2024 06:08 AM
The 9120AXE and 9120AXP models have a 4-port Smart Antenna (DART) connector. External antennas including the Self Identifying Antennas (SIA) can be connected to this Smart Antenna connector using the 4-port DART cable connector (AIR-CAB002-DART-R=). Both the 9120AXE and 9120AXP also support Smart antennas.
The 9120AXE (C9120AXE-x and C9120AXE-EWC-x) and 9120AXP models (C9120AXP-x and C9120AXP-EWC-x) support four external, dual-band RP-TNC connectors.
Cisco 9120AXP is same as 9120AXE, except it is used for locations like stadium with high gain antennas (professional installation)
Jagan Chowdam
/**Pls rate useful responses**/
Jagan Chowdam
ā11-21-2024 06:35 AM
@Mkvts as @jagan.chowdam 9120AX come with 4 smart Antenna (Dart) Connectors. You can refer to following link for use the connector.
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/guide-c07-742311.html
