air-ap 2802i-e-k9 web interface
waled1990
Community Member
Hi everyone, i have a 2802i-e-k9 running mobility express version 8.10.171.0 (converted from lightweight)
i would just like to find out how to access/enable the ap web page if it has one. Similar to below, can get to mobility express config fine. thanks in advance
If it is realy ME, web page should be there by default. Do you have access to it somehow?
balaji.bandi
i followed the below guide to make my Wireless AP to Me simple steps:  GUI works as expected.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_010.html
below video steps :
https://www.youtube.com/watch?v=38f5VLp-qnI
BB
Rich R
You've misunderstood what ME is.  The screenshot you're showing is for an autonomous AP.  That doesn't exist anymore.  The ME WLC GUI is where the AP is monitored, viewed and configured now - there is no GUI for the AP.
The only AP GUI which can be found on a CAPWAP AP is the Office Extend AP config pages
https://mrncciew.com/2013/01/15/configuring-oeap/
But OEAP is not supported on ME.
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/feature-matrix/ap-feature-matrix.html#_Toc87523902
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
