AIR-AP1231G-E-K9 and AIR-AP1231G-A-K9 not joining?
rastapasta1969
I?ve installed a AIR-AP1231G-A-K9 to substitute an old 1220 (I need to connect some 811g clients).
Now all clients (Cisco, Linksys and D-link) reconnect to this new AP, except a 1231 (AIR-AP1231G-E-K9) configured as WGB which turned OFF it?s radio (it turns ON only if setting it as AP).
There?s a known incompatibility between the AIR-AP1231G-E-K9 (European) and AIR-AP1231G-A-K9 (American) versions of this AP?
Software versions are 12.3(8)JA for both AP?s, the configuration is standard with web128 encryption.
Any tip for me?
bye
j-block
Level 4
Level 4
AIR-AP1231G-E-K9 refers to european standards so the power and channel option depends on european channel.AIR-AP1231G-A-K9 refers to North american standards.So the power and channel option depends on American Channel.
