3560 POE problem
jms112080
Level 3
Level 3
We are using 3560 POE switches to power Symbol AP's. All the documentation I've read says the 3560 can power up to 24 AP's. We are only able to plug in 7 to 8 AP's before some start dropping out. Is there any other possible cause for this other than lack of power?
oj88
Level 4
Level 4
How much power does the Symbol AP consume? Based on the 3560's data sheet, it can provide a maximum of 15.4W each for all of the 24 ports.
Based on Symbol documentation 15.4W is more than enough to power the AP. Is there a switch command to show the amount of power it is recieving from the wall/ups? The "show power" command on a 3560 works but gives no output.
sethgarnar
Level 3
Level 3
if you do a "show power inline" it should give you info like this
ACADB-300C-92.3#sh power inline
Available:370.0(w) Used:109.8(w) Remaining:260.2(w)
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/1 auto on 12.2 AIR-LAP1131AG-A-K9 3 15.4
Fa0/2 auto on 12.2 AIR-LAP1131AG-A-K9 3 15.4
Fa0/3 auto on 12.2 AIR-LAP1131AG-A-K9 3 15.4
Fa0/4 auto on 12.2 AIR-LAP1131AG-A-K9 3 15.4
Fa0/5 auto on 12.2 AIR-LAP1131AG-A-K9 3 15.4
Fa0/6 auto on 12.2 AIR-LAP1131AG-A-K9 3 15.4
Fa0/7 auto on 12.2 AIR-LAP1131AG-A-K9 3 15.4
Fa0/8 auto on 12.2 AIR-LAP1131AG-A-K9 3 15.4
Fa0/9 auto on 12.2 AIR-LAP1131AG-A-K9 3 15.4
