AIR-AP1252G-E-K9 access point and AIR-WLC4402-50-K9 controller
captainmajid
I have configured AIR-AP1252G-E-K9 (lightweight)and AIR-WLC4402-50-K9 controller and connect within same LAN but AP is not showing in the controller, please help
controller configuration is attached
Majid
krishanmistry
Please provide more information e.g:
What software version is running on the WLC?
What is providing DHCP, and what is the scope?
Have you tried any debugs on the controller to see any LWAPP join requests, reaching the controller.
You mention above the part number for a autonomous AP then state it is LWAPP. Was it converted? If it was, is it attaching to the same controller it was initially attached with in the conversion process? If not, the SSC is the issue. You must install the SSC hash on the controller. Next, look at the date and time on the controller to insure accuracy. Next is the AP getting an IP address on the same subnet as the controller management and AP manager interface? If not then insure you get an IP address and enable option 43 or DNS lookup of the controller.
Hi, thanks for your response
A) Yes, I converted the following AP from autonomous to lightweight mode but with the help of (CiscoAironet-AP-to-LWAPP-Upgrade-Tool-v34), not through attaching the controller
B)Please tell me the steps of, how to install SSC hash on the controller and DNS related configs
Thnks & Best regards,
Majid
Required information is attached
No debugging messages are showing on controller
