10-31-2012 05:06 AM - edited 07-03-2021 10:57 PM
Hi All,
My current setup is an AP1262n located ~400 feet from my WAP321. I would like to take the wireless signal coming from the AP1262n and rebroadcast it using a WAP321. Can someone help me with the configuration setting on these two devices.
10-31-2012 05:10 AM
Hi Paul
I don't believe that the 321 is able to connect in bridge or repeater mode to a 1262. The 321 access point is more small business while the 1262 is more enterprise. In order to support repeater or bridge mode on a 1262 AccessPoint advanced configuration settings like Aironet extensions are needed which I don't think the 321 AccessPoint supports.
10-31-2012 05:29 AM
400' might be pushing it, but why not just setup the 1262 as an access point and use the wap321 as a repeater if it supports that. Not really suggested because performance will be poor, but if your okay with it, that would be the only way. You could always get another 1262 and setup one as an ap and the other as a WGB (workgroup bridge).
