06-20-2019 08:24 AM - edited 07-05-2021 10:35 AM
We have recently been advised to install 1562i access points for a new external wireless service. These were purchased and now installed in one location. One more location to follow. They are showing on the WLC (AIR-CT5520-K9) as downloading and have been for some time.
Having read a bunch of old threads I believe I need to add US as a country code (currently we only have Canada selected as this is where we are based)
Code has recently been updated so should not be a concern it is 8.5.140.0
I guess my questions are - after adding US as a country code should there be any issues with the APs functionality ? Why are these APs US specific only ? Will a reload be required to complete the request (I see disabling A and B radios will need to be performed) ? Is there a Cisco specific page that explains regulatory domains and why some Aps are specific to that domain.
Any help will be appreciated.
Dean
06-21-2019 12:01 AM
06-21-2019 08:15 AM
Yes already tried that multiple times.
06-21-2019 06:06 PM
06-22-2019 02:35 PM
06-24-2019 06:24 AM
Cisco TAC advised the following
8.5.140.0 supports 1562I Access point. If your controller is running that version, you can just add country domain and connect your AP. Below I have provided doc which has compatability information of software version and AP,s . So we will add the country code in the next maintenance window and check following that.
06-24-2019 07:04 AM
06-24-2019 07:41 AM
Thank you will look to do that too.
