AIR-AP1852I-S-K9 suddenly doesn't want to power on using POE
Do Tien Dung
My company is using device AIR-AP1852I-S-K9
installed since 2019, the device is continuously connected to the POE supply switch.
Currently the devices are out of warranty, and we are facing a situation where we can't power using POE, remove the device inside, I see that the board has burned IC
I asked the supplier, they said that the AP1852I series often had this error and needed warranty.
Please give me the solution?
Thanks & Best Regards,
Do Tien Dung
Technical staff - Service support department
IT Operations Center
57 Huynh Thuc Khang Street, Dong Da District,
Ha Noi Capital, Viet Nam
www.vnptit.vn
live:.cid.edce5e4917b06b34
@Do Tien Dung wrote:
Our device hasn't restarted in 1 year
Is the operating time of the equipment used continuously, so the device will burn the circuit?
No, just cheap components designed to only last a few years.
In the last 3 years, this forum has seen a rise of 1800 failures.  If the APs fail, RMA it while it is still possible (before End-of-Support date).
6 Replies 6
Do Tien Dung
Do Tien Dung
www.vnptit.vn
Leo Laohoo
Yes, the AP is still covered under Cisco's Limited Lifetime Warranty.
The AP can still be RMAed and does not require any maintenance contract.
HI @Do Tien Dung
As this device is without warrant, I would sugest you to try use a external power supply (not a POE injector) and check if the device boots and works fine. It could be a way to save it.
Edit: Ask for your vendor a power supply compatible with your AP, similar attached photo.
The AP is still covered under Cisco's Limited Lifetime Warranty.
Currently, a lot of devices in my company do not want to be powered on by POE
Is the operating time of the equipment used continuously, so the device will burn the circuit?uptime.png
Do Tien Dung
www.vnptit.vn
