ā10-27-2022 04:15 AM
Hi, I am struggling to configure my AP model air ap2802i-e-k9
after booting the I keeps on displaying the following:
And when I try to go on to config t mode It does not allow me.
Please help....!!!!
ā10-31-2022 01:17 AM
@Sbu I'm 99% sure you did not follow the steps I advised.
1. Convert the AP to CAPWAP mode.
2. Install the CAPWAP image (not the ME image)
https://software.cisco.com/download/home/286304510/type/286288051/release/15.3.3-JK7
Avoid 8.10.181.0 for now due to the bug mentioned in my signature - there'll be a new release shortly.
3. Convert (and upgrade) to the new ME image:
https://software.cisco.com/download/home/286304510/type/286289839/release/8.10.171.0
ā11-01-2022 04:34 AM
I was using the wrong command, but I managed to upgrade to the new version, and also converting to ME, I am just stuck on getting my Guest WiFi working, I have configured the all the SSIDs with respective VLANs but no success.
ā11-01-2022 06:11 AM
If you want help with that you'll need to be a bit more specific than "no success".
As in how is it configured and what is not working?
Have you done debugs on a client MAC?
ā11-01-2022 01:14 PM
I am trying to configure Multiple WLANs two to be exact with WLANS in two different VLANs, I have configured both the internal and guest (WLAN) SSIDs with the VLANs , But only the internal one has internet access.
ā11-01-2022 04:55 PM
Do the clients get an IP address?
ā11-02-2022 12:25 AM
No they do not
ā11-02-2022 04:52 AM
Is the vlan configured on the switches and allowed on the AP switch trunk ports?
ā11-10-2022 01:28 AM
Sorry for the late reply, Yes the switch is configure and it allows trunk ports, but the only the Guest wifi has a problem. I am not able to connect to is at all
