AIR-AP2802I-Z-K9 - Downgrade Firmeware
eduardo-correa
I need to downgrade the firmware of an AIR-AP2802I-Z-K9 from version 17.6.4.56 to version 8.10.151.0 but I can't find a procedure for this.
What is the best way to do this manually with direct console access on the access point?
Based on 8.10.151.0 code, AP needs to run 15.3(3)JK5.
Download this file "ap3g3-k9w8-tar.153-3.JK5.tar" from Cisco and put it in TFTP server.
On the AP CLI issue the command "debug capwap console cli", then run the following command.
archive download-sw tftp://<tftp server IP>/ap3g3-k9w8-tar.153-3.JK5.tar
Jagan Chowdam
/**Pls rate useful responses**/
