Catalyst 9800: SSH Works, Web Interface Fails with Invalid Credentials
prcant
Community Member
I recently configured a Cisco Catalyst 9800. After setting up the device via the console, I enabled the web server and configured the management interface along with user credentials. SSH access is working perfectly, but when trying to log into the web interface, I receive an "Invalid Credentials" error.
Steps:
  1. Configured the management interface with an IP address.
  2. Enabled HTTP/HTTPS server.
  3. Created a user with privilege 15.
  4. Enabled SSH access, which works without issues.
What could be causing the web interface to reject the credentials while SSH works fine? Are there additional configurations required specifically for the web interface? Any guidance would be greatly appreciated!
10 Replies 10
Can I see the wlc config
MHM
what exactly do you want to have?
Show run | in http
This part friend
MHM
WLC#Show run | in http
ip http server
ip http secure-server
destination transport-method http
WLC#
https://www.wiresandwi.fi/blog/cisco-wlc-9800-base-initial-configuration-cli
Check this there is some command related to http is missing
MHM
logging discriminator FILTER msg-body drops Configured programmatically by process SEP_webui_wsma_http
webauth-http-enable
ip http server
WLC#
I keep having the same problem
ip http authentication local
MHM
ok
CORP-WLC01#Show run | in http
webauth-http-enable
ip http server
ip http access-class ipv4 HTTPSXX_ACC
ip http client source-interface Vlan999
CORP-WLC01#
the access list in the ACLs was missing
Now gui is working
Glad issue solve
Have a nice day
MHM
jagan.chowdam
Validate the WLC config with WLC Config Analyzer https://cway.cisco.com/tools/WirelessAnalyzer/ and go through the critical Advisories and fix them.
Jagan Chowdam
/**Pls rate useful responses**/
