AIR-AP3802E-B-K9 external antennas
npugyp0k
Hi everybody! I have a bit of confusion with the above mentioned AP antennas setup. It has 4 plugs. I need 4 dipole antennas so that both 2.4ghz and 5ghz networks function. Which ones should i get..?
Scott Fella
You would get 4 dual band antennas.  Here is some reference:
Dual-Band Articulating Dipole
AIR-AN2524DB-R/AIR-ANT2524DG-R/AIR-ANT2524DW-R
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/product_data_sheet09186a008008883b.html
-Scott
-Scott
Scott Fella
-Scott
-Scott
DJX995
Level 3
Level 3
AIR-ANT2524DW-R
OR
AIR-ANT2535SDW-R
AIR-ANT2524DW-R are long and have slightly less gain but can be articulated to point in a specific direction.
AIR-ANT2535SDW-R are short and have more gain but can not be articulated.
Would you please elaborate on how to articulate them properly? I ended up getting four AIR-ANT2524DW-R like Scott Fella suggested
The antennas should be vertical in position with dipole antennas.
-Scott
-Scott
