AIR-BR1310G-A-K9-R
i have this cisco aironet 1300 series.. i would like to console it.. but i cannot get to the console..i think i have a problem with its baud rate,
it will not accept the 9600.. anyone who has tried this?
thanks
6 Replies 6
Saurav Lodh
Level 7
Level 7
Console Port
You can use the power injector's console port for entering CLI commands  to manually configure controller information. Follow these steps to  connect to the power injector's console port:
Step 1 Connect a nine-pin, female DB-9 to RJ-45 serial  cable to the RJ-45 serial console port on the power injector and to the  COM port on a computer.
Note The Cisco part number for the  DB-9 to RJ-45 serial cable is AIR-CONCAB1200. Browse to http://www.cisco.com/go/marketplace to order a serial cable.
Step 2 Set up a terminal emulator, such as Windows Hyper  Terminal, to communicate with the access point. Use the following  settings: 9600 baud, 8 data bits, no parity, 1 stop bit, and no flow  control.
Step 3 The access point default (out-of-the-box)  username, password, and enable password are all Cisco (case  sensitive).
Note You must remove the serial cable  from the console port when your configuration is complete.
i tried it many times already but i cannot go to the user interface mode..
What do you mean user interface? Are you able to get into the console and issue commands?
-Scott
i am not able to get into the console and issue command
Can you add additional info? Do you have this set properly
-Scott
yes i have set it properly as what you have stated.. this model has no mode to press to make it to the factory setting.
