AIR-CAB005LL-N connectors
justin.cetko
Can anyone tell me what type of connector is on the AIR-CAB005LL-N (male or female)?
In the list of N antennas some come with male connectors and some with female.
Justin
Thats right!!
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
7 Replies 7
Surendra BG
AIR-CAB005LL-N is used for N type male connector and usually used for 1410 bridge...
Surendra
Surendra BG
Also..
AIR-CAB005LL-N = 5-ft low loss cable, one straight N connector, one 90-degree N connector
Surendra
Surendra BG
Thanks and sorry for not being more specific but I am desiging a mesh network with 1520 series APs and I need to know what type of connector is on both ends of the cable.
Justin
Hi Justin,
Ok..
AIR-CAB010LL-N = MALE N type Connectorrs both the ends..
Surendra
Surendra BG
I double checked! its Male both side..
Surendra
Surendra BG
Thanks again,
So I guess I need to have a custom cable made with male/female connectors if I want to extend any of the 1520 series 2.4GHz omnidirectional antennas!
Thats right!!
Surendra
Surendra BG
