Management and native Vlan in different subnet??
harrismat91
Can i have a management ip and native vlan in different subnet on a AIR-1242 and 2960 switch?
Native on Switch = 1.
Interface vlan 100 = 10.10.1.25X /24
BVI ip in vlan 100 = 10.10.1.25X /24
-HM-
6 Accepted Solutions
Surendra BG
AFAIK, both the management and the Native will be the same... I assume.. You have Native Vlan as 1 on the switch and Int Vlan 100 on the switch for Routing?? Am i correct?? lemme know whats ur needs are.. which will help me to help you out!!
for your question..
Normally we specify the native vlan on the Switch and the AP so that the communication happens.. if there is a mis match the communication wont happen..
Looking forward to hear from you!!
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
Thanks for the update..
Ok in short YES this can be done.. here is the AP configuration..
Step 1>> Configure the SSID and map it with respective Vlans..
Step 2>> Create the sub interafce int dot11 0.5 / int fa 0.5 (encapsulation dot1q 5 , bridge-group 5)and int dot11 0.6 / int fa 0.6(encapsulation dot1q 6 , bridge-group 6)
Step 3>> Create the sub interface 0.100 for both Radio and Fa and under this (encapsulation dot1q 100 native , bridge-group 1)
Step 4>> Make sure all the interafces are up and running and Try to ping the VLAN 100 interafce ip addr from the AP to verify.
Surendra
Surendra BG
ok!! strange.. at the time we issue the command "encap dot1q 100 native" bridge-group 1 should be of no problem.. issue these comands..
int dot11 0.100
bridge-group 1
end
int dot11 0
no bridge-group 1
int fa 0
no bridge-group 1
end
Surendra
Surendra BG
Did that help?? lemme know if you are facing any issues.. will help you out!!
Surendra
Surendra BG
Thats Nice to hear!! Regarding the native vlan.. it depends.. just try by not configuring native and see if we are able to ping or issue the command "sho mac-add table" and see if we are learning the vlan 100 traffic..
if not try configuring the native and do the same as above..
Surendra
Surendra BG
Ok!! Looking forward to hear from you..
Surendra
Surendra BG
12 Replies 12
Surendra BG
for your question..
Surendra
Surendra BG
Thanks for the quick reply..
Yes you are right.. I have interface Vlan 100 on the switch which i am using for clients, Interface Vlan 1 is not used.
I need 2 SSIDs, which will be to Vlan 5 & 6. I need the traffic flow to AP for Vlan 100. how to solve?
-HM-
Surendra
Surendra BG
Thanks again,
configured but, its not taking bridge-group 1 under .100 sub-int. any idea?
-HM-
int dot11 0.100
bridge-group 1
end
int dot11 0
no bridge-group 1
int fa 0
no bridge-group 1
end
Surendra
Surendra BG
Surendra
Surendra BG
Yes that did the trick.. Do i need to configure native as Vlan 100 on the switch port??
-HM-
Surendra
Surendra BG
give a try and i will update you
Thanks a lot..
-HM-
Surendra
Surendra BG
The Native 100 helped.. thanks again.
-HM-
WOW!! Thats great to hear... thanks for posting on CSC..
have a great day!!
Surendra
Surendra BG
