Air-CAP1552E-A-K9 AP reset to factory default
jackie005
I need to reset the Air-CAP1552E-A-K9 AP to factory default. I have consoled in and issued the 'reset' command but it did not reset to factory. I've also manually pressed and released the reset button on the AP. Can I get some help please on setting this back to factory? Thanks
5 Replies 5
Philip D'Ath
What about telling the controller to reset it to factory defaults?
Hi. Thanks for the suggestion but it will not associate with the controller. I was able to get reset to factory default steps for the Air-CAP1552E-A-K9 AP from tech support.
When you console in to the AP did you do:
clear capwap private-config
These are the steps she sent me.
Please try the following at the AP CLI:
#debug capwap console cli
#debug capwap client no-reload
#capwap ap ip address <IP ADDR FROM AP> <NETMASK IP ADDR FROM AP>
#capwap ap controller ip address <MANGEMENT IP ADDR FROM WLC>
#capwap ap ip default-gateway <AP GATEWAY IP ADDR>
#test mesh mode local
This allowed me to re-ip the AP and get it to associate with the controller.
redes.espoch
Hello, could you help me with the image for the Air-CAP1552E-A-K9 ap
