AIR-CAP1552E-A-K9 can no longer be seen by wifi controler
7.0.220.0 software verion AIR-CAP1552E-A-K9  stop talking to controllers today
error was *emWeb: Jan 16 21:26:11.800: %SIM-3-INTFGET_GIG_ETH_FAIL: sim_config.c:209 Failed to get the Interface number of the Gigabit Ethernet Port
*emWeb: Jan 16 21:20:49.008: %SIM-3-INTFGET_GIG_ETH_FAIL: sim_config.c:209 Failed to get the Interface number of the Gigabit Ethernet Port
*emWeb: Jan 16 21:17:47.821: %SYSTEM-3-NOTIFY_SAVE_FAIL: nvstore.c:167 Failed to save data for a Non-volatile component. Registrar ID: 42.
*apfMsConnTask_0: Jan 16 21:14:01.938: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:14:01.938: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:13:51.978: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:13:51.978: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:13:51.898: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:13:51.898: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:13:41.949: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:13:41.949: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:13:41.864: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:13:41.864: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfReceiveTask: Jan 16 21:13:30.507: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:290 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*apfMsConnTask_0: Jan 16 21:12:51.662: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:12:51.662: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:12:41.622: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:12:41.622: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:12:31.591: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:12:31.591: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:12:21.545: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:12:21.545: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:12:11.554: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:12:11.554: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:12:01.478: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:12:01.478: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:11:51.444: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:11:51.444: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:11:41.391: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:11:41.391: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:11:31.347: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:11:31.347: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:11:21.310: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:11:21.310: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:11:11.281: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:11:11.280: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:11:00.404: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:11:00.404: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*apfMsConnTask_0: Jan 16 21:10:50.143: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:10:50.143: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*spamReceiveTask: Jan 16 21:10:50.016: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:49.101: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:48.188: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:47.059: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*apfMsConnTask_0: Jan 16 21:10:40.110: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:10:40.110: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*spamReceiveTask: Jan 16 21:10:35.800: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:34.883: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:33.969: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:33.055: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*apfMsConnTask_0: Jan 16 21:10:30.068: %APF-1-PROC_RSN_WARP_IE_FAILED: apf_80211.c:2374 Could not process the RSN and WARP IEs. error processing RSN IE.MobileStation: 04:c9:d9:e6:ab:e5, SSID:Cisco,AP: 84:78:ac:e8:46:80.
*apfMsConnTask_0: Jan 16 21:10:30.068: %APF-3-VALIDATE_DOT11i_AUTH_FAILED: apf_rsn_utils.c:915 Could not validate the WPA security IE.Received an invalid Authenticated Key Mgmt WPA OUI code from mobile. Mobile:04:c9:d9:e6:ab:e5
*spamReceiveTask: Jan 16 21:10:23.396: %LWAPP-3-REBOOT_ERR2: capwap_ac_sm.c:2626 AP 84:78:ac:e8:46:80 joined to the controller currently experienced a reset earlier - Uptime: 0 days, 00 h 22 m 10 s. (AP reset )
*spamReceiveTask: Jan 16 21:10:22.014: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*apfReceiveTask: Jan 16 21:10:22.012: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:290 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*spamReceiveTask: Jan 16 21:10:22.007: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:10:20.804: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:19.817: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:18.902: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:07.061: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:06.145: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:05.229: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:04.392: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:10:04.315: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:10:04.314: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:10:03.106: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:10:03.104: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:10:02.120: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:10:02.119: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:09:45.093: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:09:45.092: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:09:44.178: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:09:44.177: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:09:43.264: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:09:43.263: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:09:26.230: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:09:26.229: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:09:25.321: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:09:25.320: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:09:24.410: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:09:24.409: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:09:07.385: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:09:07.384: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:09:06.473: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:09:06.472: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:09:05.562: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:46:80
*spamReceiveTask: Jan 16 21:09:05.561: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*spamReceiveTask: Jan 16 21:08:52.556: %DTLS-3-HANDSHAKE_FAILURE: openssl_dtls.c:631 Failed to complete DTLS handshake with peer 192.168.1.2
*spamReceiveTask: Jan 16 21:08:52.553: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 Could not send join reply, AP authorization failed; AP:84:78:ac:e8:61:80
*spamReceiveTask: Jan 16 21:08:47.539: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1080 AP with same name AP8478.ace8.4680 exist. Using default name AP8478.ace8.4680 for this AP.
*fp_main_task: Jan 16 21:08:26.607: %CNFGR-3-INV_COMP_ID: cnfgr.c:2219 Invalid Component Id : Unrecognized (75) in cfgConfiguratorInit.
*cdpSocketTask: Jan 16 21:08:26.543: %LOG-3-Q_IND: rrmCfg.c:1501 RRM LOG: Airewave Director: Configuration has been sanitized -- save configuration to commit
*fp_main_task: Jan 16 21:08:26.421: %RRM-3-RRM_LOGMSG: rrmCfg.c:1501 RRM LOG: Airewave Director: Configuration has been sanitized -- save configuration to commit
*fp_main_task: Jan 16 21:08:26.225: %MM-3-MEMBER_ADD_FAILED: mm_dir.c:909 Could not add Mobility Member. Reason: IP already assigned, Member-Count:1,MAC: 00:00:00:00:00:00, IP:
in short a know probem with these with there certifices that had expired and will not update, as i have remove them and reinstall them they still expired , i found this know probem with this software, or this version with ios,
i have two units that went down at once wich was kind odd  what i need is update certifce file with instucktons how to install them or update to get around this probem as these run  around my home for video camears now all are off line ,  u see how this is a real big probem  i do not have a contrack with cisco i am disable but under your ueser agrement that if users shows that they have a known probem cisco would release  a fix for it,   units are  would be gratefull for fix in eather update or replaceing the certifices but i found only a update will fix this,  thank u please post replay or update to cincinnatiman45211@gmail.com the usa account i cant access nor i can chnage it here, this something else i need help with
to fix the email as i cant change it
Leo Laohoo
Hall of Fame Community Legend Hall of Fame Community Legend
The only way to fix this issue is to upgrade the firmware of the WLC.  7.0.220.0 is extremely ancient.
No valid Service Contract?  No problem.  Read on:
  1. Read the "Multiple Vulnerabilities in Wi-Fi Protected Access and Wi-Fi Protected Access II" Security Bulletin (aka KRACK)
  2. Scroll down to the "Customers Without Service Contracts" section.
  3. Read the 2nd paragraph very, very carefully.
NOTE:  Please refer to the Cisco Wireless Solutions Software Compatibility Matrix and look at Table 6 to determine if the WLC &/or AP code support.
Recognize Your Peers
