Mobility Express Controller 8.10.130.0
bahaa Eddin
I upgraded one Mobility Express Controller to 8.10.130.0 version, after the upgrade I noticed the option to create/delete a dynamic interface is no longer exist, is there any workaround for this issue or I should downgrade the version again in order to create the interfaces.
Scott Fella
Workarounds are usually to downgrade or upgrade. Try to downgrade back and see if the option is there. If not, you can always factory reset the ap and build it back up.
-Scott
patoberli
I haven't an ME setup here, but did you clear the browser cache after the upgrade?
Did it maybe move to the advanced settings?
I tried this from CLI , anyhow the only solution for this to downgrade the version to any then upgrade it again to this version, since this version support the following command while some other version not:
"config network web-auth https-redirect enable"
thank u all
