AIR-CAP3602I Console Issues
sstojanovski
Frequent Visitor
Frequent Visitor
Does anyone know the reason why I cannot type any commands via console on the AP. I have tried rebooting it several times and even powered it via power only and no interface connected but still no luck.
Flow Control:     RTS/CTS
Flow Control must be OFF.
9 Replies 9
Leo Laohoo
Cannot type any commands?  You mean you get the error message "Command disabled"?
No, its like keyboard strokes do not work. No error appears that command is disabled.
What is the settings for your console?
Have you tried other computers/laptops?
Yes I have tried from 3 different laptops
Baud rate:          9600
Data bits:           8
Parity:               None
Stop bits:          1
These are just the standard I have for all my Cisco Devices
Changed
to
Flow Control:     XON/XOFF
Now it works
Please don't forget to mark this thread as "Answered".
Thanks.
Abhishek Abhishek
Hello Janovski,
As per your query i can suggest you the following solution-
You are not able to type any commands via console on the AP so the problem is FLOW CONTROL as it must be "OFF".Please enable it.
Hope this will help you.
