AIR-CAP3702I-E-K9 fail to upgrade
Sorin Dimitriu
Hi!
We are trying to do an upgrade a WISM2 from 8.4.100.0 to the recomended version 8.5.171.0.
We have more than 300 APs CAP3700 and CAP3800.
All CAP3800 upgraded succefully to 8.5.171.0, but all 3700 failed...
Can anyone know why they are failling?
Information about CAP3700:
cisco AIR-CAP3702I-E-K9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FCW1923NPJ3
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.4.100.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 80:E0:1D:0B:CF:90
Part Number                          : 73-15243-01
PCB Serial Number                    : FOC1922549Q
Top Assembly Part Number             : 068-100375-02
Top Assembly Serial Number           : FCW1923NPJ3
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP3702I-E-K9
Directory of flash:/
    2  -rwx         287   Jan 1 1970 00:07:16 +00:00  info
    3  -rwx       69772  Dec 12 2022 00:09:04 +00:00  event.log
   38  drwx         576   Mar 1 1993 00:04:05 +00:00  ap3g2-rcvk9w8-mx
    4  -rwx         268  Dec 13 2022 10:24:41 +00:00  env_vars
    5  -rwx         333  Dec 26 2022 10:33:18 +00:00  capwap-saved-config-bak
    6  -rwx          64  Dec 12 2022 00:08:59 +00:00  sensord_CSPRNG0
   10  drwx        2496  Jul 21 2017 00:20:48 +00:00  c3700-k9w8-mx.153-3.JE
   75  drwx           0   Mar 1 1993 00:01:05 +00:00  configs
    8  -rwx           0  Jul 21 2017 00:09:40 +00:00  config.txt
   77  -rwx          64  Dec 12 2022 00:08:59 +00:00  sensord_CSPRNG1
   78  -rwx        1950  Nov 22 2016 09:50:15 +00:00  atf_override_config_slot0.txt
    7  -rwx      134374  Oct 19 2022 22:08:52 +00:00  event.r1
  137  -rwx        1950  Nov 22 2016 09:50:15 +00:00  atf_override_config_slot1.txt
    9  -rwx         333  Dec 13 2022 10:24:53 +00:00  capwap-saved-config
   79  -rwx      131073  Jan 20 2023 18:04:28 +00:00  event.r0
   81  -rwx       12312  Dec 26 2022 10:33:17 +00:00  private-multiple-fs
40900608 bytes total (18392064 bytes free)
11 Replies 11
balaji.bandi
Are you upgrading from WLC ? have you tried reset and upgrading manually ?
check some guides and bugs :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/managing_software.html
BB
Hi BB!
Yes we tried to upgrade manually and we reseted the AP, is still failling the upgrade.
SD
Post complete process logs to understand what is wrong ? also look @Leo Laohoo  FN.
BB
The unique error log that appear is:
Mon Nov 21 19:18:28 2022        AP with MAC: 80:e0:1d:25:97:40(C1-AP80e0.1d11.cf34) upgrade image from verion:8.4.100.0 to 8.5.171.0 failed. Failure Cause:Problem extracting image .tar file or image is not a valid...
Console into the AP and reboot.  Post the entire bootup process.
 Failure Cause:Problem extracting image .tar file or image is not a valid...   <-- no idea what file you are using ?
BB
Hi!
Follow the output of WISM2 and CAP3700.
> Product Version.................................. 8.4.100.0
As already advised before, you should update to 8.5.182.7 as per link below.
8.4 has been end of support for more than 5 years and that release is deferred!
https://www.cisco.com/c/en/us/td/docs/wireless/deferral/Deferral_Notice_8_4_100_0.html
https://www.cisco.com/c/en/us/products/collateral/wireless/8500-series-wireless-controllers/eos-eol-notice-c51-740436.html
Rich R
Yes Leo has the answer there. You should ignore the "gold *" version on software downloads - that doesn't get updated anymore and cannot be trusted (in other words 8.5.171.0 is broken) .  Refer to the TAC recommended link below for what versions to use.
In this case you should be using 8.5.182.7 - see link in my signature below.
