AIR-CT2504-K9 upgradation & AP compactability
We are planning to upgrade WLC (AIR-CT2504-K9) which is presently running on software version - (8.0.152.0). Below are the Access Points models which are presently registered on this WLC -
AIR-LAP1131AG-E-K9 & AIR-LAP1042N-E-K9
Please let me know which latest version will support mentioned Access Point models.
as per document,
your 1131's last support OS version is 8.0.152.0
1040 series's last support OS is 8.3.150.0
2504 controller supports up to version 8.5
rate and mark as answer, if this helps
Good luck
KB
as per document,
Good luck
KB
For future reference this site has the compatibility of software to AP and WLC models
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
*****Help out other by using the rating system and marking answered questions as "Answered"*****
