Overlapping subnets in different wireless VLANs (same SSID)
Alex Mac
Level 3
Level 3
Hi all,
It's the first time that I'm facing this challenge but I may run into a scenario where different dynamically assigned VLANs might host the same subnet, like 10.10.34.0/24. The VLANs are extended to different VRFs so there won't be any conflict in terms of routing.
As far as I know I always thought of wireless VLANs as simple L2 domains but I'm told that for mobility WLCs take into account L3 information and two VLANs managed by the same WLCs and with the same L3 IP addressing used within may run into problems. Like all he VLANs were flattened at WLC level and two client with the same IP address but in different VLANs could be seen as one by the WLC.
Does anyone have experience on this?
Could anyone help in shedding some light on this please?
Alex
8 Replies 8
Mark Elsen
 - Note sure if this can work referencing : https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/68100-wlan-controllers-vlans.html
         Dynamic Interfaces on WLCs
 >... If the port is untagged, all dynamic interfaces must be on a different IP subnet from any other interface configured on the port.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Arshad Safrulla
Hi Alex,
I assume that you are running 9800 platform and Flex AP's. If the same IP is seen twice by WLC it will report as IP Theft and client will excluded as per the configured timeout. Please refer to the below enhancement request.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvr98802?rfs=iqvred
As you can find in the above link, this enhancement is added starting from 17.3.3 and higher. Make sure you have the correct IOS-XE code running in your WLC. Config guide as below
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-4/config-guide/b_wl_17_4_cg/m_vewlc_flex_connect.html#concept_hvw_sjw_clb
But that's only for flex local switching.  I think it will still be a problem for anything centrally switched?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
I think the scenario which you are referring will be very low. I have very rarely come across networks where they use overlapping IP addresses even if it's in different VRF's. I think if AP's are in local mode we need to look at the design as a whole. Only solution I see is converting the AP's to Flex.
Not sure what you mean by "low". The impression I have is that when dealing with all the stuff to prevent intrusive action by unauthorized clients or duplicated address the controller flattens the VLANs but I don't know why. It would be that simple. Just imagine the same (DHCP snooping etc etc) in a switch, would you consider it normal? 🙂
Hi Alex,
You can't even configure dynamic interfaces with overlapping IP subnets in AireOS (Dynamic interface is compulsory in AireOS world), but in 9800 platforms you really don't need L3 SVI's unless there is mdns gateway or dhcp relay. So technically you can get away wth configuring the L2 VLAN which offers same subnet under 2 SSID's in 9800. The real problem happens when there are 2 clients with the same IP address. WLC will mark the client to be excluded for IP Theft.
If AP's are in local mode there is a workaround (only in 9800 no L3 SVI's), but not recommended. You can divide the DHCP IP scopes
VLAN 10 - VRF DATA - 10.0.0.0/24 - SSID EMPLOYEE - DHCP SCOPE 10.0.0.1-10.0.0.128
VLAN 20 - VRF PERSONAL - 10.0.0.0/24 - SSID EMPLOYEE2 - DHCP SCOPE 10.0.0.129-10.0.0.254
By manipulating the DHCP scopes you are avoiding duplicate IP issue. But you have to compensate on the available IP addresses.
Alex Mac
Level 3
Level 3
Hi Arshad,
unfortunately we are speaking of the same SSID and VLANs assigned dynamically by the RADIUS, that would be the scenario.
Alex
Still the same theory applies, you cannot have 2 clients with same IP. You can try to manipulate your DHCP scope to stop assignment of same IP to 2 clients.
