AIR-LAP1131AG-E-K9
samirshaikh52
Level 2
Level 2
Hello Experts,
We are in process of purchasing 5 Cisco 1131AG AIR-LAP1131AG-E-K9. However I've some doubts to clear
a. Firstly, we dont have WLC
b.Will the AP be provided with IOS? What version it will be.
c. Can I convert them to AIR-AP1131AG ?
d. Or keep them as LAP
Please can someone help pe to clrarify these doubts.
Surendra BG
Please use the below doc and this will resolve the issue that we are facing..
https://supportforums.cisco.com/docs/DOC-14960
lemme know if this answered ur question!!
Surendra
Surendra BG
30 Replies 30
andrew.brazier
Level 4
Level 4
If you've bought LAPs you will need a WLC or they won't work. I believe you can convert them to IOS APs but I think you need a WLC to do so (it holds the IOS image that the APs will upload). Either way, you either need to order IOS based APs or a controller.
Surendra BG
Surendra
Surendra BG
Thanks for your replies.
Will the access points are delivered with IOS ?
Yes it is.. but the Model number will be AIR-AP1131AG-E-K9 for IOS and AIR-LAP1131AG-E-K9 for LWAPP..
Lemme know if this answered ur question!!
Surendra
Surendra BG
Hello Surendra,
What are limitations I will get with LWAPP ?? Can you please tell me ??
To get the LWAPP AP up and running you need the WLC.. there is NO limitations at all.. its all advantages!!
Saves time, saves energy, saves config overhead etc etc..
Surendra
Surendra BG
Is it compulsory to have WLC to make LAP work..
However, one of my friends organization they have 15 access points. And they are working fine withoutr WLC.
Here is there output of show version. Pease can you advice
Cisco IOS Software, C1130 Software (C1130-K9W7-M), Version 12.4(10b)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 19-Mar-08 18:08 by prod_rel_team
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (fc2)
MDSFH_AP01 uptime is 2 weeks, 6 days, 4 hours, 28 minutes
System image file is "flash:/c1130-k9w7-mx.124-10b.JA3/c1130-k9w7-mx.124-10b.JA3"
MDSFH_AP01#sh ver
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1131AG-E-K9   (PowerPCElvis) processor (revision B0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1311Q1ND
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:23:04:B8:BC:7C
Part Number                          : 73-8962-14
PCA Assembly Number                  : 800-24818-13
PCA Revision Number                  : A0
PCB Serial Number                    : FOC13063XJT
Top Assembly Part Number             : 800-29144-03
Top Assembly Serial Number           : FCZ1311Q1ND
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1131AG-E-K9
Configuration register is 0xF
The code running on the AP is IOS... Yup we can have 100 APs as well!! it will work awesome.. but while troubleshooting or re configuring the APs, this time we need to configure all the 100 that means 100 times configuration!! Just like school assignment , If we have WLC then just one time, then it will pushed to all the APs in one GO!!
Lemme know if htis answered ur question!!
Surendra
Surendra BG
Thanks for your kins guidance and awesome clarification.
AIR-LAP1131 will work as a normal Access Point or I had to upgrade them to AIR-AP1131 ??
If you want to use this AP as an IOS AP, then no need to do anything.. currently the AP is in IOS mode..
lemme know if this wnswered ur question and please dont forget to rate the useful posts!!
Surendra
Surendra BG
Hello Surendra,
Your replies has been very helpful and cleared.I
I've heard that AIR-LAP are supplied without and they need to be join with WLC to make it work. Is that true ??
Ok..
here is the thing!! AP-LAP or AIR-AP is just the HARDWARE... the software that runs on it will decide whether we need the WLC or not..
Normally AIR-LAP comes with a LWAPP image or software by default.. and AIR-AP comes with IOS image or the software by default..
that is..
c1130-k9w7-tar.124-25d.JA.tar here, W7 tells us that this is IOS image and does not need the WLC.. where in...
c1130-rcvk9w8-tar.124-21a.JA2.tarhere rcvk9w8 tells us that this is LWAPP image which needs WLC..
We can use the above images on both AIR-LAP and AIR-AP to convert and use, just like how you have done.. that is W7 image on the AIR-LAP
lemme know if this answered ur questions!!
Surendra
Surendra BG
Hi Surend,
Well that  was very great and descriptive explanation..almost I am on end..may be this will be my last question.
How can i know that the AP is Lightweight or autonomous through software way meaning (ios commands)
From the below image..
Surendra
Surendra BG
