AIR-LAP1142N-E-K9 wil support 2.4GHz and 5GHz or not
Hi got little confuse that 1142N-E0K9 will support both 2.4 and 5 ghz or only 2.4 .
Breeze Joseph Kuriakose Sr Network Engineer
Leo Laohoo
The "2" means that it has two radios:  2.4 Ghz and 5.0 Ghz
Saravanan Lakshmanan
Yes, it supports dual radio.
Is it the only AP having an issue.
Do you see both radios available on Radio page?
Wireless>> All AP>> Select the AP>> click interfaces tab>> Do you see A radio
check the A radio admin status, enable if not already.
Did you select the right CC or what country code did you select on WLC?
Does Msglog shows messages related to regulatory domain failure?
Wireless>> All AP>> Select the AP>> click interfaces tab>> Check regulatory domain status for A radio
get, AP#show cont d1
Reboot the AP and get the log from the start and post it here.
Amjad Abdullah
1141 supportes only 2.4 GHz
1142 supports both 2.4 and 5 GHz
Rating useful replies is more useful than saying "Thank you"
Yup,
Cisco ap versions are easy to remeber ...
1140 is the model series
1141 is a spcific model - 1 = 2.4 Radio
1142 is a specifci model - 2 = 2.4 / 5 Ghz.
Same is true about other model
3500 series
3501 is a spcific model - 1 = 2.4 Radio
3502 is a specifci model - 2 = 2.4 / 5 Ghz.
You will also see "e" and "i"
e = external anetanns
i = internal antennas
AIR-CAP3501E-A-K9
AIR-CAP3501I-A-K9
