AIR-LAP1262N
gilles.donze
I would like to transform this acces point to an autonomous AP. Is it possible ?
Could you tell me how can i do that ?
Thanks in advance
Davidwagman1
Level 7
Level 7
Hi Gilles,
You can convert it from lightweight to autonomous. Download the autonomous software from the software download center.
Get a tftp server running on your machine. I use solarwinds free tftp server. Put the software in the tftp root folder.
Put the AP on the network (same subnet as your machine w/ tftp server) and connect the console cable and get up a terminal connection. (make sure you can ping the AP from the computer and the reverse)
AP>en
AP#debug lwapp console cli or debug capwap console cli
AP#config t
AP(confg)int fa 0
AP(confg-if)  ip addr (same subnet as that of the laptop)   (or maybe it will get a  DHCP during        boot watch the output)
AP(confg-if)end
AP#archive download-sw /force-reload /overwrite tftp:///
More detailed steps can be found here.
Best,
David
Please rate helpful posts.
Davidwagman1
Level 7
Level 7
Hi Gilles,
AP>en
AP#config t
AP(confg)int fa 0
AP(confg-if)end
Best,
David
thanks a lot for you answer
I can use it now with IOS it's working fine. I have one more question : why the http applet is not complete ? the web access to this AP migrated does not contains the same functionalities as AP 1250 autonomous. Can i upload an othe software ?
Kind Gilles
