04-27-2015 09:30 AM - edited 07-05-2021 03:03 AM
In doing testing with the OEAP602I Access Point, I noticed that it is limiting the bandwidth over my wireless connection. It is currently setup with a CAP/WAP tunnel to our WLC2504 to provide our Corporate Wireless network to my home, but I am also using the function of the AP to provide my personal wireless network. I have noticed that the AP limits my bandwidth to 50 - 66% of my actual speed. If I plug into the ports on the back of the AP I get my full bandwidth.
WLC2504 software Version is 7.6.130.0
04-27-2015 11:54 AM
I'd check the following on the WLC:
- show client detail mac-address:
RSSI - is coverage okay?
SNR - is the signal quality good?
Channel - which band is in use, prefer 5Ghz if supported
Current data rate - has the client negotiated a data rate capable of exceeding 60Mbit/sec
- show ap auto-rf 802.11{a/b} ap-name:
Channel utilisation - is the airtime being used by another 802.11 station, or noise? Typically there are a lot of other things to check, but the OAP 600 doesn't support CleanAir.
I'd not expect too much from the OAP600, particularly for corporate throughput since the AP is handling encryption in software. Cisco suggest 10Mbit/sec would be the maximum for encrypted/encapsulated CAPWAP data.
Pete.
04-27-2015 01:27 PM
Does this information display for clients that are connected to the Personal Network SSID on the 602s? I was unaware of the 10 Mbit/Sec max for the encryption tunnel. That may cause us to rethink deploying these devices.
04-27-2015 01:42 PM
I've not tested that, I'd be interested to know if you get the same monitoring data for personal SSIDs. Either way, you can usually determine the RSSI and data rates from the client, and the channel utilization data is available for the radio.
Here's the reference to 10Mbit/sec-
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-600-series-officeextend-access-point/data_sheet_c78-651456.html#_ftnref1
Hope this helps,
Pete.
