AIR-PWRINJ-30= instead of AIR-PWRINJ4=
Hello All,
We have ordered AIR-PWRINJ-30= instead of AIR-PWRINJ4= for a customer for 2702i APs. Both are showing 30w output.
My question is Can the AIR-PWRINJ-30= be used instead of AIR-PWRINJ4= for the 2702i APs. On the face of it - they seem to be working fine and I am not seeing any radios down. Will I lose any functionality?
Incidentally AIR-PWRINJ6= is the replacement model for both models.
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/eos-eol-notice-c51-737338.html
Thanks/DP
George Stefanick
I dont see any reason why you can not. Output is output.
Please rate helpful post!
www.my80211.com - Blog by a WiFi engineer for WiFi engineers
www.wifitraining.com/about-wifi/ - WiFi Training by hands on WiFi Engineers, Experts and Cisco Wireless VIPs
d.friday
Level 4
Level 4
Durga,
You should be fine, I've included a break down of power injectors Cisco provided at Cisco Live this year
The 2702 AP requires only 15w of power to run and the AIR-PWRINJ-30 will supply up to 30w of power.
AIR-PWRIN 2 & 3 PRE-802.11N APS
AIR-PWRIN4 802.3af (15.4W) and pre standard (30W) Designed for .11n and .11ac Wave1 indoor Enterprise APs
AIR-PWRIN5 802.3af (15.4W) low cost injector Designed for Access Points that use 15W or less
AIR-PWRIN6  802.3af (15.4W) & 802.3at (30W) injector Designed for all current Enterprise .11n, .11ac Wave1 and Wave 2
AIR-PWRINJ6 is recommended for all newer Enterprise indoor
Access Points (replaces earlier injectors) for most applications
*** Please rate if you find this info helpful
mohanak
No loss of functionality, as it provide the same output.
