AIR-SAP2602I-C-K9 not working at 2.4GHz
jay3
I have a AIR-SAP2602I-C-K9 which is not showing the 2.4GHz radio in the GUI configuration.When I configure dot11radio 0 on cli (which I assume is the 2.4GHz radio) it still does not work at 2.4GHz.
The AP is working fine for 5GHz.Find attached.
Please assist
5 Replies 5
Pls provide below CLI ouput
1. show interface summary
2. show run int d0
3. show run int d1
4. show controllers dot11Radio 0
Rasika
Hi Rasika,
Thank you for your response.Please find the output you requested attached below.
Jay
ap#show controllers dot11Radio 0
interface Dot11Radio0
Radio IZ 5GHz, Base Address 189c.5d6c.1e60, BBlock version 0.00, Software version 4.18.2
=> counterintuitive radio0 is 5GHz and not 2.4GHz
post the same output for radio1
The dot11Radio 1 is also showing 5GHz. How does it occur for dot11Radio 0 to be 5GHz? Are these radios changeable?
the  2800/3800 series do have an option to enable two 5GHz radio's
but you specify the 2600 series..... afaik this model can't.
when you access the web-interface of the device what does this tell you?
is it possible to do a reset-to factory-defaults? and start from scratch?
