Aironet 1200 with 802.11g and a radios
kimremick
Community Member
Can a 1200 AP with an "a" and 'g" radio be used as a Bridge (for backhaul) on the "a" radio and an AP on the "g" radio at the same time?
Kim
Stephen Rodriguez
yes, you set the A radio to be in root/non-root mode, with the SSID set as infrastructure. Then on the G radio you leave it at default and set whatever auth/encryp you want.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
HTH,
Steve
Do you know if the "a" radio in a 1200 would communicate with the "a" radio of a 1410 bridge? Same frequency? Can't seem to find it on the 1200 and 1400 product literature.
