I have two Cisco Aironet 1252 that I want to configure as a point-2-point bridge. Now I want to know if this configuration supports the 802.11n protocol.
Screech
So long as you have the right antennas for the distance, and can get RSSI/SNR that will do the N rates, yes you can do N bridging.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Scott,
I found the following statemen in the release note of IOS 12.4 (25d) (http://www.cisco.com/en/US/docs/wireless/access_point/ios/release/notes/12_4_25d._JArn.html#wp291685)
802.11n HT Rates Apply Only to No Encryption or WPA2/AES Encryption
The 802.11n HT rates apply only to no encryption or WPA2/AES encryption. They do not apply to WEP or WPA encryption. If WEP or TKIP encryption is used, the 1250 series access points and any 802.11n Draft 2.0 clients will not transmit at the HT rates. Legacy rates (802.11a/b/g) will be used for any clients using WEP or TKIP encryption
Given this statement how do I configure AES encryption on the aironets 1252 that are configured in bridge mode as I do not see this option. If possible please provide steps using the web interface.
Screech
